Landcrab Questions
Posted 03 June 2008 - 04:18 PM
Posted 04 June 2008 - 12:38 AM
I can at least answer this question — they are intended to go straight across. The 'A' in Attu is in M17. Amchitka Island is in P27-28. I have seen this system used in hex grids before and decided to use it here since the map is relatively small.Hope this helps.GregoryI read through the Operation Landcrab .pdf, and came up with a few questions:7. Very basic question/comment: How is it intended your map coordinate system to work? It seems the numbers indetify vertical columns, but is it inteded the letters go up-to-the-right (Holtz Bay would be at V19)? In which case more letters are needed along the southern edge.
Posted 04 June 2008 - 03:18 PM
Posted 04 June 2008 - 10:16 PM
Posted 04 June 2008 - 11:30 PM
Posted 06 June 2008 - 02:49 PM
Posted 06 June 2008 - 09:42 PM
