Four easy questions; I hope.
#1 Jeff Hunt
Jeff Hunt
  • 2 posts
Posted 19 December 2010 - 08:21 AM
1. On the Advanced Reference Card, on the Morale side under the Morale column is says under reasons to take a Morale Check:"Is Suppressed when Suppressed or Broken." should this read Is Suppressed when Shaken or Broken?2. When running the AP Modifiers to Kill Table do you combine the modifiers for both Low Quality and <57mm when for example a Soviet T-70 fires?example - range up to 36" Low Quality is -2 and under 57mm is -4. Do I add these together for -6 or just take the greater penalty of the two (in this case the -4)?3. When a veteran vehicle shoots it gets it's +1 Bonus Shot. Can the die roll for the Bonus Shot qualify for a Critical chance or Misfire chance? The rules mention that this Bonus Shot is not a round being fired down range but rather an effect of Veteran shooting being more acurate.4. Condition of Target Stand modifiers on the Advanced Reference Card have these nice shaded and not shaded backgrounds. Are these separate groups of modifiers which per group you may only qualify for one? And if you are lucky you can qulify for one in each group and be very hard to hit?:) 1st GroupVechice Moving NormallyUsing Evasive Movement 2nd GroupCamoflaged3rd GroupAlley Shot4th GroupHard CoverLinear CoverHigher ElevationSoft Cover5th GroupHull Down PreparedHull Down found on HillHull Down found in OpenThanks,Bubba Cleese.
#2 gregoryk
Posted 19 December 2010 - 04:09 PM
No, it is correct as written. If a suppressed result comes up when a stand is already Suppressed or is Broken, then it takes another Morale check.
The modifiers are cumulative.
Yes.
You take the best modifer and use it, they do not stack or accumulate.
