Hi all,I was wondering if I could get some confirmation that I am doing this correctly. I want to put together a British rifle platoon. According to the rules, a section is represented with a 4-man base and the command & special weapons are represented with 2 man bases. So, a 1941 rifle platoon had a command section, 3 sections of rifles with brens, a 2" light mortar team and a boys AT rifle team. This translates to: Command Base3x Rifle/Bren Bases2" Mortar BaseBoys AT Base The command base is 9 points (before multiplier).Each of the Rifle/Bren bases are 18 points each.The 2" mortar is 7 points. How do I do the boys bases though? Do I buy them as a Rifle Support base (10 points) and then pay the extra 1 point as listed on page 53.08.11 to upgrade them? Thanks for any insight you can offer.Cheers, Chris.
Help with BPV for Infantry Companies
Chris Such
, Feb 09 2009 10:34 PM
Posted 09 February 2009 - 10:34 PM
Posted 10 February 2009 - 02:35 AM
That is correct Chris. :)Also note that you will have to purchase a Small Crew to man your 2" mortar as it is not included in the cost of the mortar itself. ;) Hope this helps... B)How do I do the boys bases though? Do I buy them as a Rifle Support base (10 points) and then pay the extra 1 point as listed on page 53.08.11 to upgrade them?
Posted 10 February 2009 - 11:13 AM
Hi Bob,Thanks for the quick reply.That helps a lot.Cheers, Chris.
