Amendment 1: Gunfire CRT Adjustments
Posted 06 August 2008 - 05:37 AM
Posted 07 August 2008 - 05:25 AM
Posted 07 August 2008 - 09:11 AM
Posted 07 August 2008 - 09:27 AM
Posted 07 August 2008 - 02:51 PM
In GQ3, any course change over 2 points on the Turn Gauge will trigger the 1 row up shift (and only a 1 row up shift). So a ship can make a 6, 8, or whatever turn the adjustment will be only 1 row up. For course changes up to 2 points, there is no adjustment. In FAI, the impact of course changes on fire is more pronouced. For each 4 point change of course (or part of) causes a 1 row up shift. So if a ship executes a 6 point turn, the adjustment would be 2 rows up (1 the first 4 points plus 1 for the remaining 2 points). For a 10 point turn, the adjustment would be 3 rows up (2 for the first 8 points plus 1 for the remaining 2 points). As before, there is no penalty for course changes up to 2 points.Hope this helps...Rule 1.5.6 states two different things for shifting the range up 1 row.First it says to shift one range up when the firing ship alters her course by a 4 point or greater change of course.Then 4 rows down: Shift up for any ship changing course more than 2 points.So when a ship changes course between 2 and 4 points, do I shift up or not?
Posted 08 August 2008 - 06:34 AM
Posted 08 August 2008 - 05:14 PM
Posted 08 August 2008 - 07:37 PM
So very true! You hit it straight on the head. In FAI, if you're out carving donuts in the deep blue sea, then the only thing you'll hit is the deep blue sea! (And royally tick off your fire control crew!)> 12 forget it!
Posted 12 August 2008 - 07:10 AM
Posted 12 August 2008 - 09:50 AM
