Water
8 replies to this topic
#1 healey36
  • 933 posts
Posted 29 August 2025 - 05:14 AM
Hey Peter, you've got some really nice representations of water on your scenery:
What's your technique (if you don't mind sharing)? The last time I did some, I used a product by Woodland Scenics to "pour" a river. Expensive, and I wasn't crazy about the results. Your finished river/stream looks really good to me...was wondering how you do it.
Paul R.
#2 Peter M. Skaar
  • 522 posts
Posted 29 August 2025 - 11:01 PM
Hi Healey
I will put together a short tutorial on how I do this with a few pictures.
  • healey36 likes this
#3 Peter M. Skaar
  • 522 posts
Posted 30 August 2025 - 11:36 AM
As you know, Healey, I use GHQ Terrain Maker for my terrain layouts.  Many of the things I do and techniques I use can be applied to other terrain systems as well.
Terrain Maker uses the 1/4" hexes for streams and rivers.  The bottom of the hex is the riverbed and 2 pieces of cut 1/4" hexes form the banks on either side if a stream or on one side if part of a larger river.
Here are a couple pictures showing the basic riverbed with paint applied.
These pictures show the water part after all the other stuff that I do to the hex.  You can see the flat base coat on the edges and then the gloss.
Here are the basic steps.
1. Paint the basic color.  I use Behr's Tannenbaum house paint for this and paint 1 coat and let dry.
2. Put on a second coat.  I use the paint, unthinned, and brush it on the hex.  While the paint is still wet, I stipple it with a somewhat stiff brush to get some ripples so it is not completely smooth.  Let this dry overnight.
3. Spray on the colors.  For the final top colors, I used 2 shades of Luftwaffe Greens by the old Polyscale sprayed from my airbrush.  I used a lighter, more muddy olive green near the banks and ford areas while using the darker greens in the middle.  This gives a bit of "depth" without having to resort to pouring resin.
4. Apply a clear gloss over the paint to make it look wet.  For me, this seems to work pretty well.
That is basically how I do it.  I usually do a bunch of river/stream hexes at once.
More coming.
  • cbrenner likes this
#4 Peter M. Skaar
  • 522 posts
Posted 30 August 2025 - 11:47 AM
Here are a couple photos of a stream with a GHQ bridge showing the unfinished banks of the stream added.
The next picture shows a completed stream hex with the banks flocked and finished.  I did not add any trees to this one.
The next picture shows 3 stream hexes together with a bridge.  The bridge is not yet complete.
  • Kenny Noe and cbrenner like this
#5 healey36
  • 933 posts
Posted 30 August 2025 - 04:41 PM
That is terrific, Peter; thanks for the description of your process. Can't argue with the results...it looks great.
I want to avoid pouring resin at all cost (which can be high, lol). I've seen some water done using Mod-Podge, which I might experiment with. I think that process is similar to yours, except no gloss overspray required (if one uses a gloss Mod-Podge).
Lots to consider as I prepare.
Paul R.
#6 Peter M. Skaar
  • 522 posts
Posted 31 August 2025 - 01:06 PM
Here are a few more pictures showing stream and river hexes.
Here is a river with pontoon bridge across it.  This is probably a narrower river as each piece has a bank on one side.  To make a wider river just add more 1/4" water hexes in the middle with no banks.
Another view.
A stream/narrow river with ford.
A ford in a stream with road hexes.
  • Kenny Noe, healey36 and cbrenner like this
#7 healey36
  • 933 posts
Posted 13 October 2025 - 09:51 AM
Perhaps the greatest lesson learned here is the colors used on the "water". Scale colors is a notional concept that can be tough to grasp.
If I was ten years younger, I'd chuck all of my scenery and move to the GHQ product. It looks like terrific fun to play with.
#8 Peter M. Skaar
  • 522 posts
Posted 14 October 2025 - 10:02 PM
Thanks very much, Healey!  I started my Terrain Maker journey about 36 years ago.  I now have 3 full sets but always looking to add some additional terrain features.
For one of my next projects, I will be adding a couple of bridges that span wider rivers.  I do have one CinC pontoon bridge for a wider river but would like to add a stone bridge and maybe a girder bridge.  I need to paint more Western European style buildings as well.  Lots more to do.
  • healey36 and cbrenner like this
#9 healey36
  • 933 posts
Posted 15 October 2025 - 12:37 PM
Lots more to do.
Running out of miniature and table stuff to do is like reaching the end of the internet...ain't happening. I suspect I'll stay busy with this stuff until they shovel six feet of dirt on top of me.
