Schurzen Effects on German Tanks
19 replies to this topic
#1 Peter M. Skaar
  • 512 posts
Posted 06 March 2017 - 01:44 PM
In 1943 many German tanks were provided with "Schurzen" to better resist Soviet AT rifles fired from the flank.  The additional side benefit of the Schurzen was a stand-off for heat rounds as well which made those much less effective.
Since the Schurzen were fairly thin, what benefit would be gained against larger AP rounds of 45mm and up?
In the game there is no differentiation for different ammo types fired at the flanks of German tanks fitted with Schurzen.
Here is a possible home rule to better differentiate the effects of different ammo on these.
1. ATR and Heat rounds would be the standard effect.
2. AP rounds in the 45 to 57mm caliber or less would add +2 to the normal side armor.
3. AP rounds of larger than 57mm and up would only add +1 to the normal side armor instead of the full Shurzen effects.
Anyone have any thoughts on this?
Since this extra armor is fairly thin, I really don't see it having a full effect against standard AP rounds than the other two types I listed.
Thanks,
Pete
#2 Kenny Noe
  • 1,070 posts
Posted 20 March 2017 - 10:45 AM
Pete,
I've asked out MP manager to chime in.  he should post something soon.
#3 Peter M. Skaar
  • 512 posts
Posted 24 March 2017 - 12:18 PM
Hi Kenny
Thanks for the heads up.  I am really interested to see what you guys think plus anyone else on this forum that has played and enjoyed Mein Panzer.
Pete
#4 Bob Benge
  • 1,232 posts
Posted 25 March 2017 - 07:16 PM
Hi Peter,
There is a Schurzen rule though it is not defined as such. The rule is in Mein Panzer Core Rules, Chapter 9, page 9.4, DV (Defensive Value) section and it states:
"In some cases, there will be two values listed, where the first value is used against AP attacks, and the second value is used against any type of HEAT attack."
Now when we reviewed this I had done some research into Schurzen and found that it was predominately used to prevent ATR rounds from destroying tank road wheels and causing a track to be thrown, thus immobilizing the vehicle. The Schurzen was typically thin sheet metal and, in some cases, even bed springs wielded to a frame mounted on the side of the tank. I remember a good discussion on the subject with the group and found that Schurzen would have relatively no impact to a high velocity round. So we kept it simple and said if the vehicle had a double number for side armor then HEAT rounds would use the second value. I looked at your suggestion and would be inclined not to use it. The reasoning is, is that a +1 armor rating would equate to 10mm of armor and +2 , 20mm of armor and since we are dealing with sheet metal and bed springs I don't think this would be an accurate representation of the effects of a high velocity round.
Hope this helps, :)
#5 Peter M. Skaar
  • 512 posts
Posted 27 March 2017 - 04:37 PM
Overall, I don't have any major issue with this interpretation.  Since these schurzen were originally designed to reduce, if not stop the effects of ATR rounds, they should be given full effect against both ATR and HEAT.  ATR rounds are essentially small AP rounds and the Germans tried to cover both the sides of the vehicle as well as the turret so there was concern that these rounds would be degraded if not stopped by the addition of this extra armor.  The effects against HEAT rounds were a nice bonus.
I'm still not sure that there was absolutely no effect on AP rounds but for game purposes I am okay with no effect for "true" AP rounds.
Thanks for chiming in Bob.
#6 Mark 1
  • 150 posts
Posted 31 March 2017 - 03:51 PM
"Schurzen ... was predominately used to prevent ATR rounds from destroying tank road wheels and causing a track to be thrown, thus immobilizing the vehicle."
The primary purpose for Schurzen was to prevent penetration of armor by ATR projectiles.  Any protection it offered to running gear was a secondary benefit.
As Pete points out, this is one reason that Pz III and IV turrets were provided with Schurzen.  No running gear there.
It is also the reason that the Panther A was provided with Schurzen.  Combat during the second half of 1943 demonstrated that there was a small area of the original Panther D armored hull side, below the sloped upper hull and above the return run of the track, that was vulnerable to penetration from Soviet 14.5mm fire. It seems that results were clear ... any vertical plate of less than 40mm WOULD be hit and penetrated by ATRs in action against the Red Army.  In the Panther A this was covered by small Shurzen.  In the Panther G the vulnerability was removed by the redesign of the hull.  All it took was 45mm of plate, or some level of sloping, to complete the protection from ATR fire.
The mechanism by which Schurzen worked was to incite wobble in the projectile.  When striking a plate for which there is marginal penetrative reserve, if the projectile is in an off-axis attitude it greatly reduces the likelyhood of successful penetration. Some portion of the kinetic energy of the round diverts into rotational force, both reducing the round's ability to dig into the armor and increasing the surface area of the penetration from the point to the sides. Enough wobble and you get a visible mark of a side-on slap and riccochet, rather than crater of an unsuccessful penetration.  These slap-marks are visible on the armor of tanks with Schurzen.
It did not take armor-grade plate to induce this wobble. So the mild-steel used in Schurzen (and even mesh screen in late war Pz IVJ's) offered little protection against rounds of substantial mass.  A 45mm or larger projectile had sufficient total kinetic energy and mass to resist significant loss of penetration through any minimal wobble, in part due to the excess of penetrative potential vs. the levels of plate protected by Schurzen, in part due to the different length-to-width ratios of the larger caliber rounds in those days.  Soviet ATR rounds were rather longer, relative to their diameters, than cannon projectiles. High L2W ratios reduce stability over time of flight in rifled (spun) projectiles, but the ATRs were not firing out to 1,000+ meters, so the superior penetration of a high L2W profile was more important than the stability in flight.
"The Schurzen was typically thin sheet metal and, in some cases, even bed springs wielded to a frame mounted on the side of the tank."
The Soviets developed the spring-steel add-on plates in the late war period. Whether they were actually bed springs is a somewhat contentious question, as it is pretty clear that they manufactured spring steel screens to be added to tanks for urban combat, but that does not mean that crews in combat zones didn't find their own improvisations as well ... some of the photographic evidence looks pretty clearly like improvisation using bed-springs.  These defenses were very specifically for protection from HEAT rounds .. most notably from Panzerfaust HEAT rounds.  The common practice of placing them on the front-half of the turret roof indicates the expectation that it was to defend from hand-held weapons (fired from upper floors in urban areas).  These defenses were effective not so much becase they increased the effectiveness of the armor through stand-off, but rather by defeating the fuzing mechanism.  The rounds simply didn't detonate when caught up in the springs.
Or so I've read.
_________________
#7 Peter M. Skaar
  • 512 posts
Posted 31 March 2017 - 05:28 PM
Hi Mark
Great to have you weigh in on this.  I always appreciate your insights and consider you to have great knowledge of these kinds of things.
I suspected, but did not know, that the gap between the skirt and the actual armor did something to the ATR round and your explanation covers it perfectly.  The same for HEAT.
I gather then, from your response, that there would be almost no benefit of schurzen (I'm talking solid plate, not bedsprings or mesh) on any round over 14.5 mm?  Would there be any effect against a 20mm or 37mm round fired from a T-60 tank or 37mm AA gun?
The bottom line for me would be - Do sideskirts have any effect, in game terms, on standard AP rounds, not those fired from an ATR?
Thanks again Mark and Bob for your input on this.  I am okay to be wrong as I am learning things.
Pete
#8 Bob Benge
  • 1,232 posts
Posted 31 March 2017 - 07:53 PM
Great info Mark! Thank you for the clarification. :)
I would say that, in game terms, you could say that trying to put any benefit to this would be a guess and out of my wheelhouse. There is no numerical evidence to work with to make any changes at this point. This doesn't preclude you Pete from using a house rule if you can put some numerical value to it.  From Mark's info maybe <45mm would gain a +1???
#9 Peter M. Skaar
  • 512 posts
Posted 01 April 2017 - 04:49 PM
Hi Bob
Thanks very much for your help.  I hope to hear from Mark about this again concerning smaller caliber AP rounds such as 20, 37, 45, up to 57.  Based on what he said, it would seem that 45mm and up would have no problems with the schurzen.  I do wonder what the "cut-off" point would be when deciding to whether the schurzen add any protection at all.
Pete
#10 Bob Benge
  • 1,232 posts
Posted 01 April 2017 - 06:28 PM
Hi Pete,
My Pleasure! I would also. I would also like to see the documentation that supports his position. If that exists I can make a change to the rules. ;)
#11 Peter M. Skaar
  • 512 posts
Posted 03 April 2017 - 12:39 PM
Hi Bob
Thanks again for your responses.
Pete
#12 Mark 1
  • 150 posts
Posted 06 April 2017 - 03:24 PM
Most secondary sources on the effects of Schurzen on ATR projectiles point back to the original testing reports from Kummelsdorf in February of 1943. It was based on this test reporting that the orders for Shurzen production and fitting to Pz III and IV were given.
I have never been able to find an original of the Kummelsdorf reports online. Doesn't mean it's not there somewhere, but if it is I haven't found it.
Perhaps the most widely accredited secondary sources are the various books by Jentz. His books on Pz III, Pz IV, Panther A, and StuG III all provide information from the Kummelsdorf 2/43 testing.  I do not know if the larger, more expansive "Panzer Truppen" volumes also contain details of these tests.
From reading secondary (and tertiary) sources I understand that the 2/43 tests assessed the impact of both 5mm non armor-grade plates, and wire mesh screens, on Russian 14.5mm ATRs at a range of 100m, and on 75 / 76.2mm HE rounds.  It is my understanding that no other types of weapons were included in these tests.
These tests were conducted due to the fighting conditions on the Eastern Front in 1942.  ATRs (both PTRS-41 and PTRD-41) had become common over the course of 1942.  For larger guns there were shortages of AP production in 1942, so it was relatively common for Soviet gunners to fire HE at German tanks.  The 30mm armor on the sides of Pz III and Pz IV was shown in combat to be vulnerable to both. As both models were up-armored on the front, the chassis were becoming overloaded, and up-armoring the sides to provide effective protection levels was simply not in the cards for these vehicles.
The findings were that both 5mm steel and wire mesh were effective.  The effects on 14.5mm ATR projectiles was to induce wobble so that the rounds side-struck the armor behind, and failed to penetrate.  The HE rounds detonated at a distance from the armor, preventing damage to both the interior of the tanks (preventing penetration or significant spalling from non-penetrating HE hits) and also reducing damage to the running gear.
As both plate steel and wire mesh were found effective, it was thought that the lower weight of the wire mesh would be a superior solution. However the lack of rigidity in the wire mesh meant that more complicated mounting mechanisms were needed. So the plate went into production immediately, and the wire mesh skirting did not go into production until more than a year later.
I have never seen a reference to primary source materials of German testing of Schurzen against hollow-charge projectiles, nor against larger AT projectiles.
However the US Army did conduct test-firings against add-on spaced armor plating as part of the Shoeburyness tests in May of 1944.  These tests, conducted near Essex in the UK, were largely set up to demonstrate the enhanced firepower of the new 76mm gun mounted in 100 M4A1 Shermans that Ordnance had rushed to the UK in anticipation of the D-Day landings, and also of the new 90mm tank gun that was being mounted in upgraded M10A1 TDs (to be re-named M36) in the states in preparation for shipment to ETO.  The primary interest seems to have been demonstrating against the armor levels expected in Tiger tanks -- Phase 1 firings were against 120mm plate at 30 degrees, Phase 2 were against 100mm plate at 30 degrees.  But the test firings included a Phase 3 firing set against spaced armor plates ... at 50mm plates that also had a 20mm plate 6 inches in front.  These Phase 3 firings demonstrated how such an arrangement could initiate the fuzing of US AP shells leading to failure against the 50mm plate, in an environment where British AP shot (solid penetrators) or even inert-filled US AP shells would penetrate completely.
However, this testing set-up does not mimic Schurzen. Rather, it appears to mimic Vorpanzer, a rarely seen German add-on armor kit produced for Pz IV with the notion of enhancing the protection of tanks that would lead assault waves against prepared defenses.
I have test results from other firing tests, such as Bazookas against Panthers, or US 37mm, 57mm, 75mm and 105mm rounds, including 105mm HEAT and 75mm HE and WP, against various test targets. But I have no primary sources for HEAT or AP projectiles against Schurzen.
The test firings of the bazooka against Panther does tend to lead one to the conclusion that just about ANYTHING between the projectile and the target plate will help defend against penetration. Wheels, tires, exhaust pipes, even tow hitches were struck by projectiles in those tests, and while bazooka rounds clearly penetrated with lethal effect when striking the armored plate cleanly on sides or rear, when they struck these various stand-off protrusions the side or rear armor was effectively protected from penetration.
Best I got, boyz.  Hope it helps.
_________________
#13 Bob Benge
  • 1,232 posts
Posted 06 April 2017 - 06:04 PM
Thanks Mark!
Great Info!
#14 Mark 1
  • 150 posts
Posted 10 April 2017 - 08:23 PM
"However, this testing set-up does not mimic Schurzen."
Hmmm.  Going back through the Shoeburyness report, it appears that there is one reference to Schurzen style plates.  To wit:
Inclosure No.2
ARMORED FIGHTING VEHICLES & WEAPONS SECTION
APO 887
SUMMARY OF CONCLUSIONS FROM ORDNANCE BOARD PROCEEDINGS No. 26495
1. 75mm APC M61 Inert loaded and Explosive "D" loaded have similar maximum perforative performances against single homogeneous plate.
2. Against a spaced plate assembly consisting of 20mm homo plate in front of 50mm FH plate, the shell failed at all velocities up to the velocity of the gun. The same shell, but with empty fuse succeeded against this target at velocities above 1780 f/s (equivalent to a range of about 850 yards with a MV of 2050 f/s). The failure of the filled and fused shell must be attributed to fuse action and detonation between the plates.
3. Against 70mm homo plate at normal or 60mm and thinner plates at 30º the shell was as successful as shot and gave detonations at distances of up to 20 feet in rear of the target.
4. The effect of 5mm and 8mm skirting plate in front of 30mm homo plate did not affect the performance and successful functioning of the fuse.
Clearly, the #4 conclusion is a reference to Schurzen level plating over side armor.
However, in looking at the accounting for all shots in the three phases of firing, there are no shots listed as against this "5mm and 8mm shirting plate in front of 30mm homo plate".  So I don't know what data drove this conclusion, but clearly someone thought that Schurzen would not impede penetration by 75mm M61 APC rounds.
Here is another piece of data from the report, which appears to be a chart of combined data (on 75mm M61 penetration testing) from TWO test firings ... Proceedings 269594 (I believe this is the Shoeburyness tests) and an earlier test firing listed as Proceedings 23114.
Perhaps the testing against Schurzen level plating was part of that ealier test firing.  Don't know ... don't have anything more on that event.
CONSOLIDATION OF DATA FROM ORDNANCE BOARD PROCEEDINGS 23114 AND 26594
75mm APCBC M61 - HE filled versus Inert loaded
Ordnance%20Test%20Firing%20of%2075mm%20M
Still no genuine primary data on the effects of Schruzen....
_________________
#15 Mark 1
  • 150 posts
Posted 07 September 2018 - 03:37 PM
I'm baAAaaack.
Regarding an earlier statement:
Well now I have seen a new reference.  So I thought I might update the information in the discussion.
I now have a copy of a German periodical, "Waffen Review", the 1. Quarter 1981 issue (Nr 40), which has an article describing WaPruf test firings of Panzerfaust  and Panzerschreck HEAT projectiles against wire-mesh schurzen, conducted in December of 1944.
The publication can be found here (Russian language website):  https://sassik.livej...com/344764.html
Scroll down to 6457 to find the article in question.
The article title is:  "Schürzen zur Verstärkung der Panzerung"  ("Schurzen to Reinforce the Armor") -- Note: the word "schurzen" translates literally into English as "apron", but for our purpose here I will retain the German word for it's current relevance to our discussion.
Here is a key portion of the article:
Am 21.12.1944 wurde in Kummersdorf ein Versuchschießen durchgeführt, allerdings nur mit den Schürzen aus Maschendraht und Panzerfaust bzw. -schreck. Ergebnis:
"Das Verhältnis der beschleunigten Masse beim Auftreffen zur Masse der Schürzen, die durch ihre Trägheit das Geschoß bremsen sollen, ist derart unterschiedlich, daß die Schürze die Geschoßwirkung nur unwesentlich beeinflussen kann. Alle Schürzen sind mit der Aufhängevorrichtung beim ersten Schuß zerstört worden." Auch wenn die Schürzen aus 5mm Blechen und nicht aus harten Drahtnetz sind, wird die Wirkung der Hohlladunggeschoße nicht bzw. kaum gemindert, wobei die allierten Hohlladungsgeschoße in ihrer Wirkung den dt. nicht nachstanden. D.h. die dt. Schürzen waren unwirksam, behinderten das Fahrzeug, teilweise sogar den Höhenrichtbereich des Geschütze, waren nicht sicher befestigt und eine Verschwendung von Material."
Here is my (!) translation of that passage:
On 21.12.1944 a trial shooting was carried out in Kummersdorf, but only with schurzen made of wire mesh and Panzerfaust or -schreck. Result:
"The ratio of the faster striking mass to that of the schurzen, whose inertia is supposed to slow the projectile, is so different that the schurzen impinge only marginally on the effect of the projectile. All the schurzen were destroyed along with the suspension* by the first shot. Even if the schurzen are of 5mm sheet and not hard wire mesh, the effect of hollow charge projectiles is reduced barely or not at all, the allied hollow charge projectiles not lagging behind the German in their effect. That is, the German schurzen were ineffective, obstructed the vehicle, sometimes even the elevation of the gun, were not securely fastened and a waste of material."
*Note: I can not dis-ambiguate this -- I do not know if "suspension" is a reference to the mounting of the schurzen, or the running gear of the vehicle.
In any case, the German WaPruf conclusion was that schurzen was a wasted effort if the purpose was defense against HEAT projectiles.
I find that a bit hard to reconcile with the results of test firings of the bazooka against the Panther conducted by the US Army 5th Tank Destroyer Group command, which I also have.  That test firing was NOT conducted to test schurzen, but rather only to determine the profitable aiming points if a Panther was the bazooka-man's target.  But during those tests several objects attached to the tank that projected out from the actual armor plating were struck. To wit:
a. Ricochet into wheel rim completely severing the tire and blasting an 8" hole in the wheel. There was no damaging effect upon the inner wheel immediately behind the one hit.
b. Direct hit upon a wheel. A 3 x 5" hole was blasted out of the wheel and two 10" radial cracks were made. There was no damaging effect upon the wheel immediately inside the one hit.
c. & d. Direct hits upon wheels. 6" diameter holes blasted – no effect upon inner wheels.
j. A hit upon the towing-jack device on the rear of the tank. A small portion was chipped away, but there was no effect upon the armor plate.
k. A hit upon one of the exhaust pipes, completely blasting it away, but there was no effect upon the armor plate inasmuch as the blast had been dissipated upon the exhaust pipe.
p. A hit upon the towing hook on the front of the tank. No damaging effect upon the armor plate.
All hits that landed squarely on the side or rear armor plate penetrated with damaging effects inside.  All hits on the upper front slope (the glacis plate) failed to detonate, as the fuze did not work well against sharp striking angles.  But all hits on protrusions also failed to penetrate the armor.  I find the outer road wheel hits particularly relevant. These were not armor-grade steel.  The rounds clearly detonated (not fuze failures), and yet the HEAT jet did not even damage the inner road wheels, much less the hull side.
I don't think there is enough information to fully reconcile these two differing results.
It seems pretty clear that the German test firings were more precisely on on-topic regarding schurzen. And the results were definitive enough that a strong conclusion was reached.  So I give that test greater weight. But it did not test US bazooka projectiles, it only made assumptions about their effectiveness.
The US test firings were not against schurzen. And, as different questions were driving the tests, the conclusions make no remark about spaced armor and it's effect in general, much less about schurzen in particular. But it did test US bazooka projectiles.
I am left in doubt.  I am not convinced that schurzen provided any effective improvement to the defense against HEAT rounds.  But neither I am not fully convinced that it had no effect. I lean towards schurzen being inneffective vs. HEAT, but really I'm only about 60/40 on the subject.
_________________
#16 Peter M. Skaar
  • 512 posts
Posted 07 September 2018 - 08:54 PM
Hi Mark
Thanks for your input.  Your comments are always insightful and well thought out.  The mystery is still there to be solved completely but maybe really never.  I may make some sort of a house rule to allow for some minor benefit but maybe not the full blown benefit as in the rules.
I appreciate it!
Pete
#17 Bob Benge
  • 1,232 posts
Posted 08 September 2018 - 10:14 AM
Good info as always Mark! Something to consider...wish you were more to the 80/20 though. LOL :D
Thank you for the post!
#18 Peter M. Skaar
  • 512 posts
Posted 11 December 2024 - 11:40 PM
This topic sort of got rehashed by me in my current AAR with a response from Kenny so I thought it would be good to go back and see how the discussion went some 6 years ago.
The full effects or lack thereof of having Schurzen are still debatable and I think the previous discussion was a good one.  Based on all of the above, I have concluded that any of the larger AP rounds would have been able to penetrate the Schurzen pretty easily with no negligible effect at least in game terms.  ATRs would still be affected and HEAT rounds somewhat as below.
HEAT Rounds hitting vehicles with Schurzen have their value halved if hitting the side armor per the DATA BOOK Note 1.
If there is any newer information out there I am interested to know.  Thanks.
Pete
#19 Mark 1
  • 150 posts
Posted 11 February 2025 - 01:30 PM
Some newer information ...
I have just now found a simulation showing the mechanism of schurzen defeating a Russian 14.5mm ATR projectile:
Note: Having some difficulty in posting the link.  Alternative - go to YouTube and search for the following channel: Dejmian XYZ Simulations, then search for the video:
"14.5mm Soviet AT Rifle vs Panzer IV skirts (Schürzen) | PTRS-41 Rifle Armor Penetration Simulation"
What it shows is a different mechanism than what I had described above. Rather than wobble and side-strike, the projectile is shown to essentially disassemble as it passes through the schurzen plate. The result is the same as was evidenced in the firing test results I have read -- an oblong indent that was interpreted as a side-strike but was in fact a trail of strikes by sub-components of the projectile. Interesting in the detail, but still the same net effect.
I believe this simulator is a reasonable (if not perfect) tool. I have seen several of the simulations on various anti-armor weapons, and they largely produce end results, at least, which appear very similar to the end results of live-firing tests. That said, the simulations have a variety of inputs (such as projectile hardness, armor plate hardness and ductility, etc.) that must be accurately  configured to get a good result. To this effect I have seen some simulations that were re-done with different inputs, reflecting updates to the information available on the historical values, which then generate different results.
Just thought I would add it to the assembled information.
_________________
#20 Peter M. Skaar
  • 512 posts
Posted 12 February 2025 - 08:52 PM
Thanks very much, Mark!  I will have to check it out.
