Torp Mounts in GQ3 A1
Posted 21 November 2007 - 02:55 PM
Posted 21 November 2007 - 11:55 PM
Posted 22 November 2007 - 04:11 PM
Ah, okay, I missed that when I was going over the revised rules, and then I had to re-read the Unit Engineering rules because I thought that it meant the same thing. But having another look I see the subtle difference (UE relates to bomb, mine, and torpedo Eng hits).Thanks.This is covered in "1.7.2 Damage Descriptions- Engineering". Basically, a ship marked 'one ER' has one main engine room and when an engineering hit is scored, the ship loses ALL power and immediately goes dead in the water. This is as opposed to the normal procedure of losing speed down to the mid point of the hull boxes (denoted by the single yellow hull box on the ship log) after one engineering hit (with a second engineering hit resulting in loss of all power and speed). Most of the ships that have this 'one ER' notation are merchants (or warships based on merchant designs)."
Okay, thanks. Is that explained somewhere in the rules? If not it should be (for lubbers like me :D)I saw the notation about the blue background indicating underwater tubes, but nothing for the capitol ship mounted side torps.The torpedo tubes aboard Hood and Renown were mounted above the waterline behind armor with a limited range of train. In game terms, this is represented by a greyed background (representing the armor) with a border (representing a limited or fixed mount).
Makes sense.Thanks much!As a general rule, the mounting of torpedoes on capital ships proved to be a miserable failure, and, in the most part, went out of favor in the inter-war years.
Posted 22 November 2007 - 04:51 PM
Posted 26 November 2007 - 02:38 PM
My understanding is that Bearn was designed to interwar carrier philosophy - that they were primarily scouting platforms. Thus, they were expected to be able to fight off scouting cruiser forces in extremis. Much the same as the original 8" gun fit on Lex and Sara.I presume that if Bearn had gone through refit, the torps would've come off.-Kle.Bearn (a converted WWI design battleship and raises the question: why on earth do you put torpedoes on a carrier???).
Posted 26 November 2007 - 04:42 PM
Posted 27 November 2007 - 11:03 AM
