I am presuming the intent is for this to apply equally to Italian 17.7" and French 16" torpedoes, however I am not sure if this is intended for the Japanese 21" torpedoes.Hull damage is further halved for smaller warhead aerial and 18” torpedo hits. Other damage remains as listed.
Amendment 1 - Japanese torpedoes
Posted 29 December 2007 - 03:32 PM
Posted 29 December 2007 - 04:12 PM
Posted 29 December 2007 - 07:23 PM
Posted 09 January 2008 - 12:35 AM
The old 24" used by the IJN (the Type 90) had a warhead very similiar in size to the standard 21" used by other nations (827lbs vs. 805lbs for the RN Mk VIII and 825lbs for the USN Mk 15). Consequently, I would consider the Type 90 to be the same (for effect) as the other nations 21". The upward adjustment would be only for the IJN Type 93.What I want to know is if the 21" and old 24" are now treated _exactly_ the same, or if the 21" is less effective than the old 24" torpedo (as it was before the Amendment 1 changes)
Posted 09 January 2008 - 11:40 PM
Thanks, but what I'm actually asking is if there would be the same downward adjustment for Japanese 21 inch torpedoes as for other nations' 18 inch torpedoes (as there was before amendment 1).Consequently, I would consider the Type 90 to be the same (for effect) as the other nations 21". The upward adjustment would be only for the IJN Type 93.
Posted 10 January 2008 - 01:43 AM
Since the IJN's older, WWI period 21" torpedoes carried a warhead roughly the same in weight as other nations 18" torpedoes, I would apply the downward adjustment to them. Keep in mind, the new torpedo damage table is designed as a common, across the board table. The key differential is warhead size, not neccessarily the diameter of the torpedo.Thanks, but what I'm actually asking is if there would be the same downward adjustment for Japanese 21 inch torpedoes as for other nations' 18 inch torpedoes (as there was before amendment 1).
Posted 10 January 2008 - 10:34 PM
Posted 12 January 2008 - 11:07 PM
Yes, if the torpedo is indicated on the ship log as 'white on black' then the hull damage is halved. 'Black on white' are unmodified and the IJN Type 93 ('red on white') get the upward adjustment.So to summarise, for _all_ nations, if the torpedoes are from a 'white on black' mount (or air launched) then hull damage is halved.
Half hull box results are marked as half hull boxes (one slash). For the quarter or three quarter results, my group rounds down to the closest half (or full) hull box (it's faster that way). Alternatively, you can round up or round down based on a die roll: even result, round up; odd result, round down (but that does slow things down somewhat).By the way if the table result is an odd number of hull boxes, would this halving be rounded up or down to a whole number of boxes or result in a box half damaged? What about if you get an odd quarter or three-quarters (if you have to halve twice because a 'light' torpedo hits a BB at shallow depth)?
Posted 13 January 2008 - 05:49 PM
In the absence of anything to the contrary though, I take it that optional rule 1.4.11 regarding Allied Torpex warheads still results in a column shift on the table, rather than any doubling of hull damage.Yes, if the torpedo is indicated on the ship log as 'white on black' then the hull damage is halved. 'Black on white' are unmodified and the IJN Type 93 ('red on white') get the upward adjustment.So to summarise, for _all_ nations, if the torpedoes are from a 'white on black' mount (or air launched) then hull damage is halved.
Posted 13 January 2008 - 09:31 PM
Yes.In the absence of anything to the contrary though, I take it that optional rule 1.4.11 regarding Allied Torpex warheads still results in a column shift on the table, rather than any doubling of hull damage.
