1/2 size turn guage
Posted 21 April 2013 - 07:00 AM
Posted 21 April 2013 - 07:44 AM
Click on the the "Downloads" tab and you will find them in the Private Access Library for GQ3.
I say "them" beacause you even get a coice of colours!
Regards, Phil
Posted 21 April 2013 - 08:34 AM
I don't have GQ3 (just FAI) so perhaps they are only available for that (or I'm going blind in my old age)
Anthony
Posted 21 April 2013 - 08:50 AM
I've ODGW turning gauges and the down loads fitted out as I've described. I like both styles, but I lean towards the plastic backed and covered as they are a bit thicker and a bit heavier. I find them easier to use to use as they are less fiddely because they are more substantial in their construct.
Posted 21 April 2013 - 03:34 PM
There's a couple of ways you can go with this. First, if you have the full sized gauge already printed out, you can take that to your local copy shop and run it through a copier at a 50% reduction. Second, if you just have the pdf, you can print it at 50% (assuming your printer has that option; not all do).Is there a PDF download of the 1/2 size turn guage? I have limited table size so I'd like to try the 1cm = 200 yds scale but unfortunately being in the UK the $5 guage in the store costs $22 postage.
What you should NOT do is use the gauges mentioned in the above messages. Those are no longer correct for GQ3 and never were for FAI. (I know, we really need to clean out all the defunct files. Someday...)
Posted 21 April 2013 - 04:04 PM
Posted 21 April 2013 - 04:32 PM
Those gauges are no longer correct for GQ3.3 or FAI. The only turn gauges that are valid are the ones included with the current rules. FAI uses a different gauge than GQ3.3 and the GQ3.3 gauge was changed with Amendment 1. The gauges you're referring to in the Downloads section PREDATE the official ones and are no longer valid.Page three of the downloads in the private access library in General Quarters 3. I cut out plastic from a "For Sale" sign I got at the dollar store and glued it to that.
Posted 21 April 2013 - 05:34 PM
Sorry guys, but the "official" turn indicators in GQ3.3 leave much to be desired compared to those previously available for GQ3 in the downloads.
The "official" ones are way too short, who wants to be constantly swapping betwixt tape and turn indicator?
Plus the previous indicators used their extra length to include useful info on formations, etc.
Please ask L.L. Gill if he (she?) would be kind enough to repeat versions for GQ3.3.
Thanks, Phil
Posted 21 April 2013 - 06:07 PM
At this time I can't say if the gauges you're referring to (which were not done in-house) will be updated (that would not be my decision). But I will forward the suggestion on.Oh dear,
Thanks, Phil
Posted 22 April 2013 - 03:22 PM
Regards, Phil
